3 inch drop
Discussion in 'Stop, Drop & Roll' started by robthompson46, Apr 10, 2007.
    robthompson46 New Member
    3 inch drop
    i have a 04 rolla and i recently lowered it 2.5-3 inches. my question is... should i get a chamber kit or would an alignment shop be able to get it right. what do i need to do
    I don't remember exactly how much mine were but I think they were around 50-60. They're not hard to install if you know what you are doing. It would help if you have access to a lift as well. It would be a bitch working on jackstands. They pretty much replace or bolt on to the steering knuckle and allows you to swing the wheel in or out to adjust the camber.
    fuzionrolla Guest
    camber kit is the best bet
    An alignment shop would use a camber kit.
    how expensive are they and are they hard to put on
    did you get yours from a local shop or on the internet? a guy who worked at firestone said that he didn't think they made one but i think he's an idiot.
    haha most normal tire shops don't know crap. I got mine at the shop which wasn't exactly local. I went to Super Autobacs in Stanton, CA to get everything done.
