Amp. Comments
Discussion in 'Interior' started by triune530, Nov 20, 2004.
    triune530 Guest
    Amp. Comments
    For my RF 10" subs.
    Take your car stereo performance up a notch with the Lanzar VIBE231 MOSFET amplifier.
    Boasting a maximum delivery of 800 watts, this 2-channel amplifier features a variable crossover and MOSFET switches to maintain rated power over a wide variety of battery voltages.
    Click on Overstock.com for huge savings on a wide selection of car audio accessories.
    Features include:
    2 x 125 watts RMS at 4 ohms
    2 x 400 watts max at 4 ohms
    1 x 500 watts max at 4 ohms bridged
    2 x 225 watts at 2 ohms
    MOSFET switches
    PWM-type power supplies
    Variable input level controls for each pair of channels
    Variable high/low pass crossover controls
    High-efficiency, heavy aluminum heatsink
    Remote subwoofer bass control
    Electronic crossover network
    Bass boost circuit
    Bridgeable at 4 ohms
    Tri-mode capable
    Gold-plated RCA inputs
    Line outs for left/right channels
    Advanced protection circuitry
    15Hz-35kHz frequency response
    90dB S/N ratio
    Shipping: Ships within 2 business days
    This product is not available in US territories or APO/FPO due to shipping requirements.
    Warranty: 1 Year Limited-Manufacturer
    Materials: Electronic components
    Model No: VIBE231
    Dimensions: 10.25 in. W x 2 in. H x 12 in. L
    http://images.overstock.com/f/102/3...cts/T961268.jpg
    $114=s/h
    lilbeastie18 Guest
    i did some research for you and went on epinions.com and all the comments i was reading were saying that the power acoustik 1600 amp is the best abgn for your buck.. will cost you about 200 but it will be well worth it, its rms is like 370, so u can run a 300rms sub with no problem and not have to worry about the amp over heating or anything, or shutting off
    triune530 Guest
    Thank you, sir.
