Amp-Stereo Power connect question
Discussion in 'Interior' started by Skabby, Sep 7, 2004.
    Skabby Guest
    Hey guyz, I think this is my first post..anyways..
    I have a Kenwood KDC-MPV5025 Stereo unit and I am connecting it to a Kenwood KAC-5201 2 cahnnel amp.
    I got my stereo installed at Cartoys, and am installing my amp myself. I have all the wiring done except the Remote Power control on the amp. When I went to connect it the the Blue/White wire on the stereo..it was already in use. The manual states its the power control for ext amplifier or power antenna.
    I do not have a power antenna, so I'm wondering what the used it for.
    I have a 2005 Corolla S.
    Skabby Guest
    K, well I got it all hooked up now. I called Cartoys who installed the stereo, and they said just to splice into that wire, so I did. Now my amp comes on but I got no output..:(
    I think the woofer is blown, is it typical for a blown woofer not to output any sound, not even buzz when blown?
    corolla_man_j Guest
    If your amp is coming on, then that is working as far as that, check and make sure that you have your RCAs connected, and make sure that your subs are in phase, after that, make sure that your amp is turned up, and make sure that your amp isn't turned off from some sub output setting on the cd player
    Skabby Guest
    I got one 12" JBL 2 coil. It was already pre-wired for 4ohm operation. As far as stereo settings, I set the output for the rca to Sub-W and turned the output all the way up to +15 (goes to +18) but nodda, zilch, not a thing..Maybe theres another setting somewhere. I'll have to check it out some more..ty for the help.
    Skabby
    Skabby Guest
    Well, I got a new MTX sub, and it kicks ass. Thanks for the help here!
    jox_rolla Guest
    look
    there are 2 blue wires on the back of your deck one with a white stripe and one without the one with the white stripe is your remote wire
