amp to power 6 x9 s
Discussion in 'Interior' started by 04 BLK S ROLLA, Apr 29, 2004.
    04 BLK S ROLLA Guest
    amp to power 6 x9 's
    could someone give me a good wattage amp and brand that would power my 6 x9's and front speakers?
    oxymoron Guest
    Kinda depends on what the speakers are...
    SSJ_Rolla Guest
    and if possible there RMS wattage too
    i have pioneer 6 x 9's in the rear and pioneer 6 and a halves up front......as far as rms im not sure
    mickeyfickymix Guest
    goto bestbuy or circuit city and check on a decent 4 channel amp, shouldn't be 2 expensive (what head unit are you using? does it have front and rear preamp output?)
    the headunit is pioneer DEH-P360 50 W x 4....it got dual preouts and subwoofer out whatever the hell that means....i have one 12 in the trunk powered by an amp which powers all the speakers.....i dont feel like im getting all the power though....does that mean i should run a separate amp to the front and rears speakers and just power the amp to the sub?
    zhentipede Guest
    in mnay set up... a separate amp to the subwoofer is best.... imo bridge it mono
    adjust the input level etc to ur liking (bass)
    a good amp that rms atleast 50 watts x 4 like rockford or jl will be very nice to power speakers inside
    the 6 x 9's rms is 80 watts 400 watts max
    the 6 and a halves are 50 watts rms 220 watts max
    i got a focal amp driving the sub right now....so the amp that i get to the front and rear speakers has to match the rms wattage or the max wattage?
    get a 400-600 watt 4 channel amp for all your interiors and then have your amp for your sub... everything should be cool
    what size power cable do you have running to the trunk?
    i dont even know kidd....i had the work done at this shady spot around where i work....first and last time im goin there......do i bridge the amp to the interior speakers?
    hm not sure what you mean by bridge? you said you had dual preamp outputs (front and rear) + subwoofer. From your battery you should have maybe a 4 guage or 8 guage running to the trunk for you existing focal amp. By a spliting box to take that 4 guage or 8 guage into 2 8 guage outputs. 1 goes to your sub-amp and the one goes to your new amp. Buy a 0.5-1 farad cap as well if you want something super clean
