another caliper question for 98 corolla
Discussion in 'Stop, Drop & Roll' started by 03silverrolla, 2004年08月08日.
    03silverrolla Guest
    I put new brake pads on my 98 corolla yesterday. I was going to put the new rotors on too but the torque plate bolts are too tight so Im going to have a friend do it. The problem is that on the right wheel I turned the bottom caliper bolt (the bolt in the pin) the wrong way thinking I was looseing it and I was tightening it. I broke the bottom caliper bolt/pin. Where can I get another one? Would it be safe to drive the car without both pins/bolts as long as at least one pin/bolt is installed?
    03silverrolla Guest
    thats what i though thanks.... i guess that was a stupid question.... also about brake rotors do I have to get new brake pads if I were to install new rotors
    donkeyman New Member
    Charlotte, NC
    One Word:
    NO!!!
    d_samurai Guest
    YES! since you dont want any early scarring or anything to damage the rotors w/ older pads...
