back seat removal
Discussion in 'Interior' started by nonamenoslogan0, Sep 10, 2004.
    nonamenoslogan0 Guest
    back seat removal
    does anyone know how to remove the back seat? also, is there any room underneath it to install two 10" subs?
    03corollaS Guest
    Just reach under the bottom of the seat cushion toward the center and squeeze together the two rails that run the length of the cushion, then pull upward to remove. I do not believe that you will be able to fit any subs under there without some major body modification as the cushion sits right on top of the sheet metal.
