Custom Audio
Discussion in 'Interior' started by ldpantoja, 2004年09月12日.
    ldpantoja Guest
    Custom Audio
    Hi, New member here. I am trying to find some kind of custom intallation kit. I want to put two 10's in my car were the 6x9 are. Is there anybody here that can help me find something?
    I have a 2003 Corolla S.
    Here are Pics of my car!!!
    http://www.cardomain.com/memberpage/443686 :D
    Mike4831 C-Town Pimp
    Statesboro, GA
    Pretty good start. Umm that really isn't possible unless u want to spend a ton of money. Subs need a enclosure of some kind. i honestly don't see how that could work.
    the car would look so much better with out the euros imo.
    teevee247 Well-Known Member
    Montreal, QC
    I think the biggest you could fit in your rear deck are 8" subs... and you'd definitely have to make your own custom enclosure, prolly out of fiberglass and MDF...
    ldpantoja Guest
    I have already seen it done. My problem is that I have absolutely no skills for this.
    I just purchased a Audiobahn 4800W Amp. and I'm looking for some subs.
    So if you know anybody that can give advice, pls let me know.
    yourownreality Guest
    Its very possible. I had 12's in mine. Ask Joel(civiceater), he sanded that panel for me for a long time to make it look and fit right.
    ldpantoja Guest
    shortys408 Guest
    i wouldnt do it. if you do your gonna have 2 6.5s for mids and highs. and 2 8 inch subs for bass. might not sound right. if u really want to your going to either want to build an enclosure below hte deck or buy free air subs.
    you can get 10 or 12 in the rear deck of you are willing to cut the reat deck. I cut it out then welded in 1/2 inch steel stock for bracing and the started to make the enclosure around that.
    The way this guy did it is simpler but it also makes the subs stick out of the rear deck. Mine are flush under a newly rebuilt deck so no criminals can see what is there; unless I take the cover off.
    RawkinDa4Door Guest
    arent there free air subs out there? i heard as long as u dont have any other speakers in the trunk to mess with frequencies its coo, also the rear deck probably be way to flimsy so probably have to make a new rear deck out of mdf.
    ldpantoja Guest
    TRD93LE Guest
    Custom Rear Deck
    There is no other way around it, if you want to put bigger speakers you have to work at it , and tune it, maybe try different audio companies will do the trick, custom MDF and fiberglass will be the best way to go. Check the CARDOMAIN websites for cars like yours with CUSTOM REAR DECKS, I am pretty sure you can get a GOOD IDEA from one of them. Good luck! Keep us posted of your findings.
    TRD93LE
