DIY for Tien Springs(pref. H-tech) on a 98-02?
Discussion in 'Stop, Drop & Roll' started by CivicEater, Jul 7, 2004.
    CivicEater Guest
    cut off half of the bump stop..
    or all of it..
    you can cut out the middle and then glue the top back on to the bottom so you keep your stock boot and the tight fit on the rod.. otherwise, it's gonna be really fugly....
    DIY?
    sBiZm Guest
    does anyone have one for h-techs, b/c i have to cut the rubber bump stop and i want to do it right. if not, any spring DIY with (or w/o pics) would be awesome. thanks, peaCe.
    Lekz Guest
    i have s.techs which are lower and i didnt cut shit...mostly cuz my mechanic didnt kno how and i didnt want him fuckin shit up. My s.techs work fine...well WORKED fine.
    sBiZm Guest
    yeah thanks, i was just hoping that someone had pics of how they did it. i sketch about taking the brakes off and all that because i never have before. o yeah, does anyone know the torque poundage to put those bolts back on? i dont want to over tighten. thanks.
    Concordmk1 Guest
    sBiZm Guest
    thanks...anyone know the poundage i need to put the bolts back on with? also, how long does it take(about) to do each(the front and back)? thanks...
    Concordmk1 Guest
    Best thing to do would be go buy a Haynes manual if you're going to do any work yourself. Or a BGB (big green book a.k.a. factory service manual) as they will tell you how as well as have diagrams and proper torque specs. They're very good investments.
    teamelementrolla01 Guest
    For The H-tech Tien Springs
    I PERSONALLY HAVE THE S. TECH TEIN SPRINGS (LOT BETTER HANDLING AND REPSONSE AND WAY MORE AGRESSIVE APPEARENCE) BUT NEWAYS WHEN YOU CUT THE BUMP RUBBER STOP CUT FROM THE VERY TOP. TAKE A TAPE MEASURE MEASURE .6INCHES FOR THE FRONT AND REAR BUMP RUBBER STOPS AND TAKE A RAZOR KNIFE AND CUT. THAT IS THE WAY THAT WORKS(IF U HAVE RIMS ON UR CAR TAKE U CAR TO A BODY SHOP AND HAVE THE WHEEL WELLS IN THE BACK FOLDED UP TO PERVENT TIRES RUBBING)
    sBiZm Guest
    i dont want to cut anything because i may want to put the car back to stock at soem point and sell it. what difference will it make if i do not cut the rubber bump stop?(with H-techs) will it affect anyhting? it is only 1.3" front and .8" back for teh drop. thanks.
