DRL disable question
Discussion in 'Exterior' started by Timbot, Nov 9, 2003.
    Timbot Guest
    I'm trying to do the DRL disable the moonshadowmadness way but i'm not real sure on something
    Heres the link
    http://www.moonshadowmadness.com/drldiy/drldiy.htm
    So anyways. You take the wire under the dash and you cut it in half. And you hook part of it up to the extension wire and hook that into your switch. But what i'm wondering is what you do with the other part that you cut. Do you just leave it hanging there or what?
    Timbot Guest
    ok scratch that i think i figured it out.. But I got another question now. Does it matter what kinda toggle switch you use? I went to radio shack and bought a "rocker switch" and it's rated 6amps at 125VAC can i use this or should i get a stronger one?
    The size of the switch doesn't really matter. The switch just connects and disconnects the ground. The headlight's power is not sent through these wires. Only signals from the ECU to the DRL control module (almost sure it's less than 12 V).
    baller Guest
    i have HID's so i didnt even need a switch.. I just groudned the wire to the chasis.. I didnt want to accidently leave the switch on and mess up my HID's
    Timbot Guest
    ahh yeah thats good thinking. I hadn't thought about that
    baller Guest
    yea just extend the wire a bit.. and ground it to bolt down there.. .. no need for a switch or anything
