I have a pioneer deck and...
Discussion in 'Interior' started by renandabomb, Apr 11, 2004.
    renandabomb New Member
    San Jose, California
    Its been taking me forever to get a freakin toyota installation kit that is why i have yet to install it... anyway i have a blue/white wire with a little connector on the end on the harness that came with the deck.. where do i connect that to? also i have a yellow/black wire that is labled mute on it.. where do i connect that to? i have a metra wireharness... i got all the color matching wires connected but those other throw me off
    aarhelger Guest
    Wires
    You don't need to connect either of them to anything. One is for a power antenna and the other is for a cell phone mute function. If you had a cell phone installed in your car you could connect the mute to the cell phone and when the cell phone rings it would mute the radio.
    the blue/white wire is labled system remote control
    on my metra wire harness i have yet to install a orange/black wire lableed the negative dimmer... what do i connect that to? also i have a blue wire labled the power antenna
    its a pioneer 7600 and a metra 70-1761 wire harness if that helps
    aarhelger Guest
    Wires
    Well you wouldn't need to connect the blue/black one. That must be used for the wired remote. Don't honestly remember about the negative dimmer (orange/black). You could check the matching pin on the connector in the car and see if that pin is used or not. I just looked at the wiring diagram for the radio and don't see any mention of a dimming signal comming into the radio.
    WebMasta33 Guest
    There are some wire you dont' need to connect.
    I installed the Pioneer 7600 in my car a month ago and my dads car yesterday.
    Follow the pioneer install guide, the one that shows you how to wire your rear speakers if you want to use them off the HU. Wire everythign that's applicable. You don't have a power antenna so you don't need that. You probably don't need the cell mute or the remote control wire either.
    what about the negative dimmer?
    SSJ_Rolla Guest
    i didnt use the negative dimmer i just taped it off
    WebMasta33 Guest
    Just cap it or tape it off
