installing aftermarket Tach?
Discussion in 'Interior' started by AE102, Mar 23, 2005.
    AE102 New Member
    does anyone on this board with a '93-97 Rolla installed a tach on their rides?
    i just want to know how before getting one.
    Search around on the forum. This topic has been covered in detail a couple times before. If you want to switch to a gauge cluster with tach, buy one and it should be as simple as switching the new cluster in if your car is a CE, DX or above model. If you have a base model, then you'll have to run a wire.
    hellapinoy 2000 Celica GTS
    Chicago IL.
    switching clusters is by far the easiest way to do it...
    AE102 New Member
    nah...i want those moster tachs that sits on the dash.
    but i couldnt find any info on how to hook them up yet.
    Chicago IL.
    i tried installing a tach on the dash before i did a swap... they said you can tap a wire from the cluster for the signal... im not sure though... took me forever to do thats why i did a cluster swap...
    AE102 New Member
    word....so do you have teh wiring sheet that i can see?
    There's a wiring diagram in the back of the haynes manual for the the instrument cluster. Don't think that's what you're looking for, but figured I'd mention it.
    Actually, I'm sure there's a diagram for the distributor too, which I belive is where you would need to run the tach wire from.
    Chicago IL.
    AE102 New Member
    AE102 New Member
    i went to teh homepage and download the instrutions.
    thanks all \(^_^)/
