Installing Ss foglights to CE
Discussion in 'Exterior' started by bigdrummerh, Jun 10, 2003.
    bigdrummerh Guest
    Installing S's foglights to CE
    Hi
    I have Corolla CE (Canadian version)
    I need your help guys!!! I installed foglights from S model and the light does not work!!!!!!!!!! when I bought this from ebay it only came with fog lamps itself. Anyhow I rechecked all the connection and I asked the dealer, they saying I might need switch, relay and moduel and they not even sure. The Technician guy point out that I need relay and switch. The swich cost $200(CDN) and there are two kinds of relay Denso $90 and tynko $35. So I ask you guys what do I need to make this foglights to work.
    stinky Guest
    make your own relay system.
    Go to Crappy tire get
    -Toggle switch (Your own prefference)
    -30A Fog light relay. (they usually hide these on the bottom shelf of the fog light kits)
    -spool of wire (#14 AWG)
    -Stake on's ( you will need at least 7)
    -Wire splicers (black tape will work fine)
    -Black tape
    Then just wire it all up yourself. Mount the switch right beside the coin holder on the car and you will be set. If you dont know how to hook that all up give me till tomorrow and I'll do up a wiring diagram. It will all cost less than the $30 they want for that relay for toyota and will work just fine.
    bigdrummerh Guest
    fog light relay
    Hi
    Thanks for the help I just have one more question what kind of 30A fog light relay shouled I use. I am asking this question because I am gonna use PIAA SPARK BLUE Bulbs. I do not want to burn up the whole circuit system.
    what kind of fog light relay use for Corolla S?
    Agian thanks for the help..
    stinky Guest
    there is only one 30A relay. You wont be doing anything to the stock wiring so you cant possibly burn anything in it up. This will be an independant system that runs off the battery.
    bigdrummerh Guest
    What brand
    Hi
    What brand of 30A fog light relay should I use? I understand there is 2 brands.
    Dealer sells 2 brands one of them is 95 bucks and the other is 35 bucks.
    stinky Guest
    but your not going to go to the dealer. You are going to go to Canadian Tire and buy a generic 30A relay for $8. Plus all the other parts I listed.
    It seems though that you dont have much experience with electrical stuff, and you may find that you cant do this on your own. If you dont know someone that knows how to do this kind of stuff, I would suggest that you suck up the cost and have toyota wire it all up for you. Sure it may cost $1000 by the time you are done, but at least it will be done right. I dont want to see you messing up your car becuase I didnt explain something good enough. And what I have explained so far doesnt seem to be clear enough based on your questions you are asking.
    baller Guest
    how do u remove that stock plastic black piece on the bumper???
    i probably gotta take off my bumper??? Probably just two little plastic pieces holding it in. not sure gotta take a look after my finals
    bigdrummerh Guest
    iTS WORKING
    Hi
    I told professional guy about the relay and he says he's got an idea. the idea was hook up the foglight wire to parkinglight, that way I do not have to install ugly toggle swith on my dash. Anyhow as test he put horn realy to foglight relay and it works!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    All i have to do is order a extra relay for foglight.
    Thanks for the help stinky!!!
    bigdrummerh Guest
    Reach behind the cover and you can feel the clip. push down the clip with you finger as you push it out.
