Engine is a 2 inch full catback exhaust good on stock 98 rolla?
Discussion in 'Powertrain' started by jtweezy, Jun 2, 2006.
size of full catback
Poll closed Jun 5, 2006.
2" is good 0 vote(s) 0.0%
2" is bad 9 vote(s) 100.0%
    jtweezy New Member
    Irving, TX
    like the title says
    monkey4005 New Member
    your stock rolla has 1 7/8" so you would really just be doing stock piping..... just my $.02
    corollution Member
    Santo Domingo, DR
    people say it's bad but i don't think so......
    teevee247 Well-Known Member
    Montreal, QC
    I'd personally go with 2.25" piping though, especially if you plan on adding more performance mods in the future (header, high flow cat, intake, etc.)
    Importedmex 2C Racing Inc.
    Chicago
    it wouldn't look bad cause like monkey4005 said its just a lil bit bigger so yea and atleast it'll be a lil bigger.
    It's not "bad" at all, just a slightly bigger stock pipe. It's "good" enough if you don't have much mod like others said.
    But aren't you have turbo man?? Go for 3" !!! :D
    pupo New Member
    If you are going to stay stock 2" is good, if you want to see some gains in your car go with 2.5".
    Atmosk New Member
    Baltimore Area, Maryland
    for our displacement, 2.25'' is pretty much ideal with a NA engine set up, 2.5'' at most if you have a heavily modded engine
    sxlostv1 New Member
    Los Angeles
    it's only 1/8 inch bigger than stock if monkey is right so i wouldn't even bother.
    Des Plaines, IL
    exactly. I saw this one comparison thing where it says what the biggest size pipe you should have depending on your engine. I believe the largest for ours is 2.25" and that seems ideal.
    sxlostv1 New Member
    Los Angeles
    why go cat-back... when you can do a straightpipe. it's easier to doo too. all you gotta do is take out the big long pipe, bang out the cat, and then stick a pipe inside where the cat would be and weld that up. Then you'll have a straightpipe. I did that (except for welding the inner pipe) and it seems to run fine. and it looks stock. no power seems to be lost, but i regret that it's sooooo loud.
    fastrolla96 speedbumps..yum
    Oklahoma
    2" should be fine. I'm thinking 2 1/2 might be good also cause your turbo'd if I'm correct.
    Wide Slip Angle New Member
    Pittsburgh, Pa
    You live in L.A., right? Don't you have some of the strictest emissions standards there?
    Silver Bullet New Member
    Yeah in So Cal we have strict emmision standard FEES and shitty air.
    I agree that you don't need piping bigger than the nearly 2" stock unless you go turbo. Buy a performance muffler. That's way better bang for the almighty buck than a cat back.
    ^^^ so your saying a muffler is better than a cat back.
    sxlostv1 New Member
    Los Angeles
    yah but who really gives a s4@%
    I think he means muffler is better than a catback which is only 1/8" larger than stock.
    rolla02 Corollalcholic
    Delaware
    Go 2.25 man it will help out
    2.25 fo sho. You'll lose some low end torque and slightly gain some higher rpm power. It won't be a power increase that'll have you beating cars you got walked by before, but it'll be something nonetheless.
    Delaware
    I have got 2.25 inch from the catback going into a glasspack muffler (resonator) to a TRD muffler and I have not lost any low or mid torque but the butt dyno says that I have gained some
