LED Lights
Discussion in 'Interior' started by FasteddieTRD, 2004年05月02日.
    FasteddieTRD Guest
    LED Lights
    I am interested in installing some of those LED's into my interior and I'm aware that they usually ocme with no wires and are not cigarette adapter ready or anything like that. The instructions say that you can install them off any wires in your car as long as there is a positive and negative wire going into the light. Because I'm not that savy with wiring and I dont want to screw anything up....HERE'S MY QUESTION.... can i plug in a cigarette light adapter.....strip the end of the wire an extennd a wire to the light and still have it work??? It sounds like a good idea and a great alternative to messing with any pre-existing wires...this way i can easily take them out.....any feedback would be greatly appreciated
    intel61 Guest
    where do u wanna put these lights? if behind the console, then u have to run the wire under the console. only drawback is it will only turn on when your car is on, so you wont get them on by just turning your lights on. you can however splice intto the wire from the cigarette lighter that is on your console, so you dont have to get the actual plug. watever way you do it, its a much easier way the the original way of puttin the leds in yourself. also that ebay auction thing is a rip off, but get it if u dont know how to do it. i would do it for cheaper if you want it, let me know, PM me.
