need help for replace rear bummper.
Discussion in 'Exterior' started by nakanari, Feb 10, 2004.
    nakanari Guest
    plz any one can shared info for replace the factory back bumpper.
    thanks/
    tony
    OC Rolla Guest
    What part do you need help with? I had to partially remove mine to add the rear skirts to my CE.
    nakanari Guest
    OC:
    thanks for your reply, bc i will recived my full kit soon.i need to know how to removed the facrory front and rear bumper, also can u give me info to install the skirt?
    thanks.
    tony
    Sasuke Guest
    Hey nakanari take pics when u done installing it. i wanna see how that drift kit looks BTW why didnt u get the cwest OR the Areoport kit r watever
    nakanari Guest
    hey bud:
    the reason i got drifter bc they have full bodykit which inculed skirt other company just making front kit, the andysport is kinda expensive. hopeful the kit will be arrvial this week:)
    FeelzRolla Guest
    alright guys get ready for a big bitch, it took me about 2 hours + to get this basterd off,
    First open ur trunk and pop the black plastic piece off, behind that is 2 screws take em off. then pull the carpet back, and on each side of the black plastic piece that u jus took off there are screws. Now for the out side, underneeth the trunk there are 2 screw like things that are a bitch to get off that is attached to the frame. Then go to ur wheel wells there is one philips screw and the rest are i think 4 of em or those things that are a bitch to get off which will remover the black plastic piece behind the wheel. Lastly there are screws behind the wheel well going into a black plastic piece. Now for mounting the after market piece, what i did was took the black plastic piece off and put some screws in that went right into the trunk, ur gonna have to rip the carpet half way off to get to the other side of the bolt and i threw a nut on there, to hold it on. Lastly I kept the styrofoam peice on and there are 2 brackets that hold the bumper on with no screws. I think that the 2 screws that i have holdin them on will be fine but ur gonna have to ghetto rig somethin else in order for it to stay on. O yea i would to this in like 30 min segments bc u start to get pissed and i started brakein things so be carefully with ur rolla
