NEED HELP PLEASE!!!!!
Discussion in 'Exterior' started by rob, May 11, 2003.
    rob Guest
    I'm trying to follow the DIY section on the Clear corners without opening the headlight, yet i'm having trouble removing bolts 4 and 5 holding the headlight on the body. Whenever i try to remove the bolt, it spins but it does not unscrew up. The washer on the other side of the screw is too hard to get too. If anyone has done this DIY can u please message me.
    Any Help would be Greatly apprecitated.
    Rob
    Jae Guest
    Toronto eh?
    I already did 5 cars.
    Clearing their corners.
    $60 job. Interested? 1-2 hours.
    jae@jae.ca
    Done professionally :)
    rob Guest
    Sorry, but i'm more of a do it yourself kind of person, i know its not that hard, i'm just having trouble with this one part...
    Can anyone give me any advice?
    stinky Guest
    make sure you have the propper bolts you are trying to take out. I found about half the bolts in that DIY didnt need to come out. And there are only 3 bolts holding the light on. the top one that you can see 2 of them, then the other one behind the bumper. You dont need to take the wheel off or tyo jack the car up (unless it has been lowered) just push the plastic back to see the one philips screw that holds the bumper skin on. then you will be able to pull it out and down far enough to take that last bolt off. You still need to pull those onse off the bottom scrape guard though.
