Need taillights DIY....Please help.
Discussion in 'Exterior' started by Bigbear588, Jul 27, 2004.
    Bigbear588 Guest
    I'm not a mechanic..or work on cars at all. I want to get carbon fiber lights for my car but i don't know how to install them.....Could someone please help me. I need the best help i can get.......definently don't want water in my taills or crooked lights. :? Is there anything i need to know about wiring?
    flavious27 Guest
    I just installed a pair of clear tail ins. It is like 10 screws you have to unscrew then re screw. At most half an hour at least 10 minutes.
    daPyr0x Guest
    corollatoys ESM
    very helpful :-D
    Bigbear588 Guest
    Thanks, but are there any tips or tricks I need to know. I heard something about sealer. What's up with that?
    Bigbear588 Guest
    giving this a bump
    shawnydone Guest
    altezza install
    I, too am trying to install my Altezzas. I went to Corolla Toys but It doesn't say specifically how you remove the connector from the original tail light. It looked like all you do is squeeze it and it should come out of the hole but mine are not budging (I had everything taken apart but that). Anybody know?
    Bigbear588 Guest
    Re: altezza install
    Shawny, I got mine done already. My uncle Michael helped me out. On the connector, there should be a small part that you are supposed to push down on and it should come out. The trunk light(back up light) is easiest, try out that one first. Can you post pics of your lights when it's done? I'll post mine soon.
    rollinintherolla Guest
    its easy, it should tkae u at least 20 minutes
    shawnydone Guest
    DIY Altezza
    I tried pushing and squezing everything on that connector and it will now un-hook from that little plastic holder on my lights. Big bear, do you know the exact part you push?
    Bigbear588 Guest
    Re: DIY Altezza
    Well the connector is like a rectangular part and there should be a slit. Did you try the trunk ones first?
    shawnydone Guest
    need help
    No i actually didn't will do wed and see what happens. Thanks so much.
    shawnydone Guest
    Bigbear588 Guest
    Re: altezza
    LOL, nice job Shawny. Same tails I have, good choice.
