new amp which to get
Discussion in 'Interior' started by shortys408, Aug 1, 2004.
    shortys408 Guest
    which would be easier on the wallet.
    a 2 channel amp that will power 150-200 rms per channel
    or a 4 channel amp thatll power 40 rms per channel?
    oxymoron Guest
    If you're not buying new speakers, then 4 by 40 Watt.
    shortys408 Guest
    or would it be cheaper to buy a 1 channel and wire the suibs in parallel? my subs ard 8 ohms. does taht mean i could wire both subs in parallel to a 4 ohm load? ther 150 rms so id need an amp taht powers 300 watts x1 @ 4 ohms rms
    oxymoron Guest
    What are you trying to do? Power your subs, or your front and rear speakers.
    superakuma Guest
    Get the 4 channel because it will be better. If you bridge speaker into one channel one speaker will max out first while the other speaker will still be asking for more. In your case, the front will max out first while your 6x9 still want more power. Your rear speakers will be fine but your front speaker will clip.
    Only get a 2 channel amp if you dont plan to use your rear speakers or if your front speaker is the same as your rear.
    shortys408 Guest
    they are teh same pretty much. the rears are 40 rms and fronts are 30 or 40 i dont know.
    superakuma Guest
    shortys408 Guest
    looks like a good amp but its more then id wanna spend. wuts a good amp like 100$ or under tahts one channel and powers 300 rms @ 4 ohms
    oxymoron Guest
    Your original question was about either a 4 or a 2 channel amp? Now it's a 1 channel amp. What is it you want to do?
    superakuma Guest
    You wont find any good or 4 channel amp for $100
    This is the cheapest good amp that I found and its for $150
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4950&item=5712768845&tc=photo
    You dont want to go cheap on amps for your speaker. You can get away with a cheap amp for your sub but for your speakers you will notice the difference big time.
    But if you really cant save up the extra $50 I would look into Profile CL series and Lanzar amp. From experiance I think they make good soild cheap amp.
    Profile CL series
    http://www.ikesound.com/product-product_id/1016
    or
    http://www.ikesound.com/product-product_id/1014
    Lanzar
    http://www.ikesound.com/product-product_id/855
    Some other 4 channel amps that I ran across when I was looking for a good buget amp
    http://www.cardomain.com/item/POWA6004HP
    http://www.cardomain.com/item/POWLT7204
    shortys408 Guest
    i would save hte extra 50$ but i dont have a job. because i just quit my job to take SAT classes. blah. goin into my junior year in high school.
