Engine oil leaking...
Discussion in 'Powertrain' started by Rolljah, Feb 1, 2006.
    Rolljah nunu
    @ home
    oil leaking...
    Just spotted a really bad oil leak right where the valve cover and the block connects. I think it has leaked into the timing belt as well. I had a relative look at it and had told me it's the oil seal and needs to be replaced along with the timing belt. Wondering if anyone has done a resealant in this area and some tips would be greatly appreciated.
    I've not driven this car in a long time since I bought it (used) and had been sitting in the driveway until recently.
    Thank you in advance to anyone that may help.
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    What kinda car is this for?
    Rolljah nunu
    @ home
    '96 Corolla
    Denver Rolla 98 impreza
    just replace your vaulve cover gasket... your timeing belt may need to be replace but just based on the age of the car its self... its all easy to do too... I just did a cover gasket in my co-workers 96 :)
    hehe timing belts... bah! glad i don't have one. :)
    Littleton, CO.
    yes sir glad I have timing chains and yes u need a new valve cover seal set
    JLee TD05 3SGTE
    NH
    Valve cover and..block? :p
    New gaskets sound like the key. :)
    toyotaspeed90 New Member
    Bellingham, WA
    4/7afe's (most that i've seen) have leaky valve cover gaskets & spark plug tube seals. I would suggest getting a set that includes the tube seals as well. Should be no more than $30 and 30 minutes of your time
    Rolljah nunu
    @ home
    thnks everyone. I'll be changing it in a few days.
    ChristianVA New Member
    okay between the valve cover and the block. well something is wrong here cuz your missing head for that block. it just looks like the valve cover gasket is leaking. and yup it would be a good time to replace a timing belt.
    That may be what's causing my oil leak. I'll have to investigate.
    tunerperformance New Member
    florida
    if you do the timing belt change your water pump at the same time save some headach for yourselfe
    OoOo great suggestion...:) I'll have to gugjest that to ivan (my buddy with the 96) when I do his belt... :)
    florida
    helps being a service adviser you learn alot of things to do when you work around cars to ave you time and money. oh you can also go to any auto parts store get an engine dye run your car for a couple of days with it in to see exactly where you have the leak so you dont waste time or your money
