Radio Install Kit for 02 Corolla
Discussion in 'Interior' started by -Goku-, May 27, 2005.
    -Goku- Guest
    Which Installation Kit do i need to get for a 2002 Corolla if i want to replace my Factory Radio????
    |-Goku-|
    you just need a wiring harness.. made by like best-kits or scosche.
    then you solder the harness that comes with the head unit to the scosche harness and it should plug right in to your stock wiring.
    -Goku- Guest
    <br />
    I know that, I meant do i need like a Kit to replace the front bezel if that makes any sense.
    midniterains Guest
    no, you just take hte mounting brackets off the old radio and mount them on the new ones. you dont need to customize anything. as long as its not a double DIN it'll look good.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    You don't need a bezel.
    -Goku- Guest
    but i need an installation kit for it to look right is what im saying and i need to know which one to get. Im not going to customize anything to put the radio in.
    -Goku- Guest
    ah gotcha, Its the sony MM9905X so Thats Single, hopefully it will look good. Thanks
