Removing Rear Bumper Cover
Discussion in 'Exterior' started by mayhem, Jun 5, 2004.
    mayhem Guest
    I have. Ok, you will have to take out the plastic piece out of the trunk. I think its 4 clips holding it on. Then behind that there are 4 nuts you have to take off. You will need an extention to reach them. (center top)In the wheel wells there are clips you take out. They are on the back side. And on the bottom there is one you will have to unscrew. After that you can pull the plastic forward and get to the screws on the top.(sides) The last thing you will need to do is take off the 2 clips under the bumper.(center bottom) I think thats it. I use 10mm socket and it doesnt take that long at all really. I put on my black widow bumper . Good luck
    Montana Guest
    Who here has removed the rear bumper cover on a 03-04 model?
    I'm replacing the bumper cover on my brothers CE once the new one gets painted. I'd like to know how difficult it is and what is involved. Tips and locations of fasteners(screws and clips) would be great.
    MT
    Montana Guest
