REMOVING THE TOYOTA EMBLEM IN THE REAR
Discussion in 'Exterior' started by nickgyro, Jul 6, 2003.
    nickgyro Guest
    i KNOW THAT IF WE TAKE OFF THE TOYOTA EMBLEM IN THE REAR IT WILL LEAVE TWO HOLE ANY WAY WE CAN COVER THE HOLES
    Nyconx Guest
    you either could do a bondo and sand it down and repaint it. or if it is metal (pretty sure that piece is plastic) you could just fill the holes with a weld and then sand and repaint it. I personaly feel it is alot of work to do just to cover two holes.
    stinky Guest
    or just get a differnet toyota symbol and stick that there to cover it.
    Nyconx Guest
    Im guess he is going with the clean shaven look to his cars trunk. but that is also another idea to find some other emblem is that is what you are looking for.
