roadtrip in lowered car?
Discussion in 'Stop, Drop & Roll' started by Ro2la, Jan 31, 2006.
    Ro2la New Member
    Los Angeles, CA
    Whats up guys, i was wondering if anyone had any comments on this. I'm expecting my tein h-tech springs to come in this week but i'm going on a roadtrip camping on friday. i was wondering if it would be a good or bad idea to drop the car before i go on the trip. I figure its a two hour drive and it would allow the springs to settle, plus the highway from los angeles to santa barbara isn't bad at all. any input/advice?
    Dr Tweak Mad Scientist
    Savannah, GA
    Go for it :)
    Ro2la New Member
    Los Angeles, CA
    haha, that was the response i was looking for, i can't wait to get them on the car.
    You taking I5? it's all smooth last I went to LA and back
    Ro2la New Member
    Los Angeles, CA
    no, the 101
    SD_S New Member
    SF, CA
    I was just about to ask the same question. Cause I'll be getting JspeXAE102 old suspension setup hopefully sometime soon when I can find a break from school. And I might be going to down to L.A this summer using I5
    dude, i have h&r w/ kyb and it's HARSH. I've driven across the country 3 times with that setup, using steelies except for the last 300 mile stretch each time.
    e_andree E
    MD
    C'mon guys....youre putting springs on your car.....drive it!
    Cape Coral, FLorida
    have fun find and find some twisties.
    teevee247 Well-Known Member
    Montreal, QC
    I'd definitely drive it, and a nice long stretch on a flat highway would be good to help break in new springs too... do it!
    ghoztrider New Member
    Suburb of Philadelphia, PA
    actually i would get it, i like my ride on the highway now, handles nice, just make sure u have an alighment done before u go or u'll wear ur tires really fast
    I run with a 1.35" drop and do road trips all the time, smooth ride
    Denver Rolla 98 impreza
    but not untill at least 500 miles after you put yer springs on... only took me 3 weeks :)
    e_andree E
    MD
    Nope, gotta let the springs settle BEFORE you get the alignment.
    And I have a 1.75 drop on my passat and I put close to 35k miles a year on it. Springs are meant to be driven with!
    Ro2la New Member
    Los Angeles, CA
    thanks for the input guys. now if this ebay seller would send my damn springs already.
    Why do you need the springs settle before the alignment?
    I thought they need to jack your car up in the air to do the alignment anyway.
    sonsofwisdom I can fix it
    Austin area
    uhm....just go over a few bumps and your good...you shouldn't have to drive 500 miles...they should "settle" very quickly...otherwise you've prolly got something loose...or wrong...or worn
    as to alignment...sometimes you jack up the car...but you set it back down.
    On the older alignment machines you jack up the car to calibrate the sensors (turn each tire a set amount 3x's)...on newer machines you just roll the car back and forth to do this.
    Very rarely do you actually perform adjustemnts with the tires not on the ground
    rolla02 Corollalcholic
    Delaware
    Go for it man, driving a lowered car is fun
    My car is lowered on S-Techs and Tokicos and I drive between DC and Atlanta all the time. I even did Atlanta to Miami and back with 4 people in the car. The worst thing you'll get is a little rubbing over big bumps.
    e_andree E
    MD
    How would you be able to get a proper camber reading with the tires in the air?
    ?? Go over a few bumps? Springs settling and springs locking into their perches/struts/shocks are two different things
    Shifty SIdeways Noob
    Memphis,TN
    i drove to maryland in my lowered car
    Austin area
    well I was actually joking about the bumps thing ;)
    Please explain though, because the springs will settle all they should when you place the weight of the car on them and back up
    (this is only because after raising a car on a lift and setting it back down, the camber will be a bit posotive due to suspension movement and what not...happend to every car when you raise it on a lift)
    ...after that they shouldn't move, sink, sag, raise, or anything...I've never heard of this in any of my suspension classes, nor has any of our techs
    In some cases you can make adjustment with the car in the air, only if the alignment rack you are using supports this...the one at our shop does, I forget why but my team leader (a Toyota Master Diagnostic Tech) had to. Since I wasn't working on it I didn't really ask.
    Though in this procedure I'm pretty sure you jack the car up so that the springs are loaded...if not...the computer can compensate
    sxlostv1 New Member
    Los Angeles
    road trip in h-techs? damn those are the softest springs in the world. no problem at all. i'm gonna do a 3 hour trip in a couple weeks. thatll be fun :)
    JLee TD05 3SGTE
    NH
    Two hours? LOL - mine has been driven from FL to NJ and back, then from FL to NH. My dad took it from FL to WI and back also..but I'm not sure if it was lowered then. It's currently driving on frost-heaved roads with a 1.8" Intrax drop..and it's still in one piece.
    Austin area
    yeah...it's gotta be 4-5+ hours to be a road trip HA HA
    everytime I drive to my parents place it's like 5 or 5.5hrs. Good stuff
