small tv placement
Discussion in 'Interior' started by ph0bi4, 2004年01月01日.
    ph0bi4 Guest
    small tv placement
    i'm installing my tv tonight, but i'm not sure where i should put it. its 5.5inx4 1/4in and about an inch thick. i'm most likely going to velcro it to the passenger side dash, just above the glove box so that hiding wires will be easy. but i would like to hear you guys' suggestions...i could use them.
    btw, this is only temporary until i can afford to have it flush in the dash.
    Logan6901 New Member
    If it is just temporary then, just put it where you are going to have it flush mounted.
    ph0bi4 Guest
    there is currently a stock head unit there :)
