speaker help please!!!
Discussion in 'Interior' started by viets7ylez, Sep 7, 2004.
    viets7ylez Guest
    hey all, i have a 98 corolla VE and I'm trying to install new speakers in the side doors of the passenger and driver sides. I got everything to get out except for the handle that puts the window up and down, i couldn't figure out how to get it off so can any of you help me realllly quick please!!
    thanks a lot :confused:
    Laz Z Kay "n00B, be kind"
    Biloxi, MS
    Under that window handle thingy, that should be a omega shape thingy. All you need to do is get that thing out, and the handle will come right off, so as the door panel.
    viets7ylez Guest
    so i gotta reach under and pull it out?
    CraigW New Member
    Try to push in on the door panel near the crank handle and you may be able to see the clip (gold/brass color) on the back of the crank handle.
    It is open on one end and will only remove in one direction, It looks like this ----> U
    CW
    viets7ylez Guest
    i cant find that thing ur talkin about, and i dont know how to open the rear speaks either!! lol im so newbie, who lives in charlotte !! that can help me lol
    CraigW New Member
    All I can say is the clip IS THERE or your handle would easily fall off.
    The rear speakers require removal of the rear deck cover there are some plastic pins that hold it in, lift the front edge and pull it out. Unless of course you dont have rear folding seats ?? Then that would be a different story.
    CW
    Nicorolla Guest
    Locate the clip, take an old rag, sock or any peice of fabric (expect to tear it a little). Work it behind the handle on the clip's open end then pull side to side until the clip pops out, then take plyers or ur fingers and pull the clip out, take off hanlde. To put the handle back, just put the clip on the handle and push it (the handle) back on the crank.
