Speaker Level TO RCA Adapter..
Discussion in 'Interior' started by windawg, Dec 29, 2004.
    windawg Guest
    For a Stock Head Unit? for a Corolla 05 S....
    i dont remember right offhand, but i'll look at it for you tomrorow.
    and yes, you could do that, but it's pretty ghetto, splicing it to the power wire on your stock headie harness (which is the same as the ACC circuit) is a better bet.
    are you talking about installing an aftermarket headie?
    if so, win, this is something different.
    windawg Guest
    i know how to install an after market stereo.. in my old Dodge car... i just dont want to buy a new head unit.... the Head unit in my dadge only fit GM cars.... Din and a Half.... dont want to spend alot on a stereo the sterei in my car is just fine... If only the Stock head unit had RCA out puts.... also i was talking about what color is the remote start from the stock head unit.. or thats only in a after market one....
    -win-
    windawg Guest
    Hi
    I just got an Speaker level to RCA adapter from the local shop and just wondering if anyone had installed one before? i know it connects to the rear speakers and to the ground.. i want to know where do i put the Remote Wire for the amp to? and anyone know any DIY site about this? thanks
    -win-
    triune530 Guest
    Put that "amp. remote wire" close to your stereo.
    statik New Member
    The remote wire goes to a voltage sensor inside the amp. when you have a positive voltage going to the remote wire the amp switches on, then off when there is no voltage.<br />
    <br />
    You need to connect the remote wire to a wire in the back of the head unit. It may have a specific remote wire which you can connect to.<br />
    <br />
    Find a wire that shows +12v when the H/U is switched on, and shows no voltage when it's off. Tap into that wire. <br />
    <br />
    Look for any wiring diagrams online, or if you may have a manual for the H/U.... wires may be labeled... You'll need a test probe too...<br />
    <br />
    Good luck.. let us know how you make out..
    yo
    i have the exact same setup as you. my new head unit should be coming in soon, and when i rip open my dash to install it, i'll take pictures of how i did my wiring (and the + voltage sensor) before i cut it all out and use a new wiring harness.
    windawg Guest
    thanks everyone...
    ummm James i have a question... do you remember what color wire you hooked up the remote wire too? and can i just run the Remote wire to the battery with a switch?
    thanks
    -win-
    corollinout New Member
    the remote wire is blue, its always blue unless you have a genaric headunit
    yo win
    wahtup, sorry this pic took so long, but here it is, this is the wire you'll want to splice into::
