tachometer help
Discussion in 'Interior' started by d_samurai, May 30, 2004.
    d_samurai Guest
    tachometer help
    this has prob been asked b/f, but how hard is it to install one of these? i really want one for my 96 4afe, but im afraid i might get stuck tryin to install one of them-even though it comes w/ instructions...any diy's around w/ pictures? thanks!
    Mike4831 C-Town Pimp
    Statesboro, GA
    Well I know the one I heped put in was 4 wires. But I only connect the 12V and the chassis ground. My friend did the other 2.
    basically 3 wires: +12, Grd, Tach Sig..
    [edit} 4th wire is probably illumination..
    all the wires you need to tap into are in the gauge cluster's harnesses
    to me its super easy..
    Statesboro, GA
    ya thats what they were.
    93corolladx Guest
    I didnt do anything in the cluster. Here's what I did, works really well:
    Power: I dont know what the connector is for, but its right behind the left hand vent, its right next to the dimmer switch, probably some option i dont have. But get a multimeter and one of the wires on the corner of that is a good power source.
    Ground: Find a bolt, best one is probably right behind left hand vent
    Illumination: Right side wire on your dimmer switch
    Tach Signal: Black/Red Wire, I think, coming off the distributor.
