Jokes Things to ponder
Discussion in 'Off Topic' started by Paolino, Sep 14, 2005.
    Paolino SolidTuned
    RAF Molesworth, UK
    Things to ponder
    In George Washington's days, there were no cameras. One's image was either
    >sculpted or painted. Some paintings of George Washington showed him
    >standing
    >behind a desk with one arm behind his back while others showed both legs
    >and
    >both arms. Prices charged by painters were not based on how many people
    >were to be painted, but by how many limbs were to be painted. Arms and legs
    >are "limbs," therefore painting them would cost the buyer more. Hence the
    >_expression, "Okay, but it'll cost you an arm and a leg."
    >As incredible as it sounds, men and women took baths only twice a year (May
    >and October)! Women kept their hair covered, while men shaved their heads
    >(because of lice and bugs) and wore wigs. Wealthy men could afford good
    >wigs
    >made from wool. They couldn't wash the wigs, so to clean them they would
    >carve out a loaf of bread, put the wig in the shell, and bake it for 30
    >minutes. The heat would make the wig big and fluffy, hence the term "big
    >wig." Today we often use the term "here comes the Big Wig" because someone
    >appears to be or is powerful and wealthy.
    >In the late 1700s, many houses consisted of a large room with only one
    >chair. Commonly, a long wide board folded down from the wall, and was used
    >for dining. The "head of the household" always sat in the chair while
    >everyone else ate sitting on the floor. Occasionally a guest, who was
    >usually a man, would be invited to sit in this chair during a meal. To sit
    >in the chair meant you were important and in charge. They called the one
    >sitting in the chair the "chair man." Today in business, we use the
    >_expression or title "Chairman" or "Chairman of the Board."
    >Personal hygiene left much room for improvement. As a result, many women
    >and
    >men had developed acne scars by adulthood. The women would spread bee's wax
    >over their facial skin to smooth out their complexions. When they were
    >speaking to each other, if a woman began to stare at another woman's face
    >she was told, "mind your own bee's wax." should the woman smile, the wax
    >would crack, hence the term "crack a smile." In addition, when they sat too
    >close to the fire, the wax would melt . . . therefore, the expression
    >"losing face."
    >Ladies wore corsets, which would lace up in the front. A proper and
    >dignified woman as in "straight laced". . . wore a tightly tied lace.
    >Common entertainment included playing cards. However, there was a tax
    >levied
    >when purchasing playing cards but only applicable to the "Ace of Spades."
    >To
    >avoid paying the tax, people would purchase 51 cards instead.
    >Yet, since most games require 52 cards, these people were thought to be
    >stupid or dumb because they weren't "playing with a full deck."
    >Early politicians required feedback from the public to determine what the
    >people considered important. Since there were no telephones, TV's or
    >radios,
    >the politicians sent their assistants to local taverns, pubs, and bars.
    >They
    >were told to "go sip some ale" and listen to people's conversations and
    >political concerns. Many assistants were dispatched at different times.
    >"You
    >go sip here" and "You go sip there." The two words "go sip" were eventually
    >combined when referring to the local opinion and, thus we have the term
    >"gossip."
    >At local taverns, pubs, and bars, people drank from pint and quart-sized
    >containers. A bar maid's job was to keep an eye on the customers and keep
    >the drinks coming. She had to pay close attention and remember who was
    >drinking in "pints" and who was drinking in "quarts," hence the term
    >"minding your "P's and Q's."
    >One more: bet you didn't know this!
    >In the heyday of sailing ships, all war ships and many freighters carried
    >iron cannons. Those cannons fired round iron cannon balls. It was necessary
    >to keep a good supply near the cannon. However, how to prevent them from
    >rolling about the deck? The best storage method devised was a square-based
    >pyramid with one ball on top, resting on four resting on nine, which rested
    >on sixteen. Thus, a supply of 30 cannon balls could be stacked in a small
    >area right next to the cannon. There was only one problem...how to prevent
    >the bottom layer from sliding or rolling from under the others. The
    >solution
    >was a metal plate called a "Monkey" with 16 round indentations.
    >However, if this plate were made of iron, the iron balls would quickly rust
    >to it. The solution to the rusting problem was to make "Brass Monkeys." Few
    >landlubbers realize that brass contracts much more and much faster than
    >iron
    >when chilled. Consequently, when the temperature dropped too far, the brass
    >indentations would shrink so much that the iron cannonballs would come
    >right
    >off the monkey. Thus, it was quite literally, "Cold enough to freeze the
    >balls off a brass monkey." (All this time, you thought that was an improper
    >_expression, didn't you.)
    BangRolla New Member
    houston, texas
    that stuffs pretty cool, i learned alot.
    Paolino SolidTuned
    RAF Molesworth, UK
    I'd heard of the brass balls one before. :) Can't validate the truth of these, but interesting to say the least.
