too much wattage?
Discussion in 'Interior' started by brownbanana, Jul 17, 2004.
    brownbanana ToadMotorSports
    Oahu, Hawaii
    too much wattage?
    I currently have a kenwood kac-929 2 channel amp powering 2 mtx 6000 12" subs..well my bro is gonna take the rolla and the sounds with it..he only wants to keep one sub but im not sure if thatll work ok..the amp produces 415 or so watts rms at 4ohms bridged and the subs max rms is 250 watts (4ohm sub)..would that be ok for the sub to have that much more power? could i just run it as a 2-channel and just leave the other blank? im not sure what to do..thanks in advance audio guys
    shortys408 Guest
    theres gonna be an empty spot from the sub hes taking?
    Oahu, Hawaii
    the two subs are bridged right now..he only wants to have one when he starts driving the corolla leaving the amp with 460 watts x 1 at 4ohms into a single 4ohm sub with a rms range of 50-250 watts..would i have to either get an amp with less power, a sub with a higher rms range, or anything else?
    shortys408 Guest
    wut about hte box? theres gonne be a box for 2 subs with 1 sub in it?
    Oahu, Hawaii
    nope, he already got a sealed box for a single 12" ..the dual 12" is gonna probably sit somewhere in my room.
    Oahu, Hawaii
    Schoat333 New Member
    hey im curious about this also i have a 12 in sub that ive been running bridged on a small 300 watt amp so the sub was getting like 280 watts but i got a new 1000watt 2 channel amp that i wanted to run this sub singley on till i can affor a dual box and another sub. is this amp gonna blow my sub.. the magnet on the sub says 4 ohm 300 watts
    SSJ_Rolla Guest
    It currently depends on the rms of the amp @4 ohms more often than not I wont use the 1000watt amp unless the gains are turned all the way down
    thats what i thought thanks
