torque converter
Discussion in 'General Discussion' started by jakejacobson86, 2004年09月10日.
    jakejacobson86 New Member
    torque converter
    If I dropped a torque converter in my car, would my off the line acceleration increase sufficiantly? just wondering, because im trying to figure out the whole torque ratio thing and how it affects the speeds of cars.
    RacingSolution New Member
    You already have a torque converter in the car now... what you can do is have it modified (Level 10 is one who does it) ... that will raise your stall rate allowing you to torque brake when launching (similar to what manuals do when they rev to 3 or 4k rpms and release the clutch).. It will also increase acceleration slightly...
    The job usually runs about $500 and then you have the labor to take it out and put the new one in... and you have you downtime while the work is done, unless you have a spare torque converter.
    a few people i know have bought a used torque converter, gotten the work done on THAT, then had them swapped out...and sold off their original one to someone who's looking to do the same thing to theirs. saves downtime significantly.
    RollaRyder1103 New Member
    Corona, CA
    or u can do what I did and just buy a modified one already and then swap them out
    this should be in engine/transmission section
    yeah i guess it should be in the engine/transmission section, sorry about that. Falnfenix, do you mean that someone could just work on my torque converter and tune it up better? do you all think I should get an already modified one or would it be just the same working on my existing?
    Tokez420 Guest
    Jake - PM Vamp about Level Ten torque converters...i think they're in New York.
