UK Garage creates V8-powered Lotus Extrema
Discussion in 'Auto News' started by Autoblog, 2009年01月26日.
    Autoblog Guest
    Filed under: Aftermarket, Tuners, Euro, Supercars, Lotus
    Click above for a high-res gallery of the UK Garage Lotus Extrema
    The UK Garage (based in... Italy) and its Lotus Extrema has taken Colin Chapman's philosophy to a level the old man never could have imagined. Built atop a Mark I Exige, UK Garage widened the track, stretched the wheelbase and created a custom Mark II body kit to fit more rubber and make room for a range of mid-mounted engines.
    On the low end of the spectrum, customers can equip their Extrema with a GM-sourced, turbocharged 2.8-liter V6 putting out 350 hp and tipping the scales at just over 1,800 pounds. A Superlight variant is also available, weighing in at 1,650 pounds and equipped with either a 2.6- or 3.4-liter V8, producing 360 or 450 hp, respectively. For those who want to go full (big) bore, the Extrema can be had with almost any GM-supplied V8, ranging from two LS3s producing either 420 or 500 hp, the 520-hp LS7 or the Corvette ZR1's 638-hp, supercharged LS9. With only 2,138 pounds to motivate, the range-topping Extrema is claimed to hit 60 in 2.9 seconds, blow through the 100 mph mark in under seven seconds and on to a top speed of 200 mph.
    In addition to the engine upgrades, UK Garage can equip any model with a manual or sequential transmission, along with an Ohlins suspension, four-piston AP Racing brakes, roll cage and other safety systems. Both race-ready and road-legal versions are available with prices starting at €66,000.
    Gallery: UK Garage Lotus Extrema
    [IMG][IMG]
    [Source: Autoblog.it]UK Garage creates V8-powered Lotus Extrema originally appeared on Autoblog on Mon, 26 Jan 2009 20:01:00 EST. Please see our terms for use of feeds.
    Permalink | Email this | Comments
    More...
    nyrican52884 Active Member
    Plymouth, MA
    Wow...:You_Rock_
    las vegas
    lotus with a LS9 s/c damn that thing is gonna be hauling ass,probally swirving left to right just pushing the gas pedal half way down.
    Ares Active Member
    Houston TX
    just make sure you have enough slicks to make sure you are planted...
    Kansas City, KS
    sick mods, dayum!
