What to clean interior with b4 painting?
Discussion in 'Interior' started by JspeXAE102, Jun 10, 2004.
    I'm glad I got to this thread before the n00bs did with their bad advice..
    acetone cleaner right before painting.. Just wipe on and wipe off because it burns the plastic a lil..
    I said it before and I'll say it again do not use primer or plastics, use ADHESION PROMOTER, then spray on your desire paint. Adhesion Promoter brands: Bulldog, Bondaid
    BUT a good combination for interior is
    -DupliColor Vinyl & Frabric for soft pieces
    -Krylon Fusion for hard plastics
    Both of which requires no primer, adhesion promoter, or clear coat..
    Prizmatic Guest
    What is the best cleaning solution to clean the lower dash and center piece with before I paint it. And would you recommend using a primer and sealant on any pieces?
